A2 interrupt on pin inop in simi
brandonb
Has thanked: 175 times
Been thanked: 173 times
Post by brandonb »
A2 interrupt on pin dont work in simulation, i checked this on the 12f683 and 16f690... however if int interrupt is on the normal B0 it does work like with the 16f1938 or 18f2685... is this something that could be fixable?
int inop in simi.fcf
(12.14 KiB) Downloaded 272 times
Re: A2 interrupt on pin inop in simi
Here are some updated FCD files for the devices you mentioned.
12F683.fcd
(5.86 KiB) Downloaded 342 times
16F690.fcd
(11.42 KiB) Downloaded 306 times
Simply download and then pop them into your Flowcode v5/FCD directory before starting Flowcode and the interrupt should then be working on the RA2 pin.
Let me know how you get on.
brandonb
Post by brandonb »
thanks ben, works like a charm :D ... is that something that would also be included in the next update?
Yep these updated files will be in the next update release.
