Init string var
JCMB
Init string var
Post by JCMB »
J create a var MyVar[12] and init it in the project expolrer as "1234567890AB"
Compile give the error: "Too many initializers"
If J change MyVar[12] to MyVar[13] or if J init it with "" compiling is OK.
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Init string var
Post by JonnyW »
C will automatically add a null terminator to any literal you give it. So your string is actually: "1234567890AB\0"
Flowcode string concatenations do not have this limitation, but assignment through intialisers is done with the C compiler. If you want that string as an initialiser, you will have to create it as a 13-element value.
On the other hand, if you do not wish to change the contents of the string once it is initialised, you can create it as a constant, which can be any length.
Jonny
