Zigbee sending <CR> after AT command
Ondra
Been thanked: 2 times
Post by Ondra »
Good day all.
When sending AT command to the XBee module do you have to send a Carriage return after each command?
Ondra
Re: Zigbee sending <CR> after AT command
Hello Ondra,
Yes I believe so, the carriage return is often used as the signal for the module to attempt to process the command string it has just received.
Ondra
Post by Ondra »
Any particular format?
Ondra
