Which Pins Are Used To Program
Darren.Smith
Flowcode V4 User
Has thanked: 2 times
Post by Darren.Smith »
Good Evening Gentleman, I Have Recently started making my own pcb's and have now decided to use surface mount pic's in doing this i am going to need to make a little board to quickly solder a pic onto so i can wire it into the eb006 programmer to program, which brings me to my question of which pins are actually used during the downloading of code to a pic, i ask this as it would be easier to tack a few pins rather than have to solder all 44, as far as i am aware pins required are vpp pgm and vdd vss, are ther any others????
cheers Dazza
Re: Which Pins Are Used To Program
Hi Darren,
This should help:
http://www.matrixmultimedia.com/support ... ?f=2&t=586
Darren.Smith
Flowcode V4 User
cheers martin, got fed up of drilling 40 1 mm holes to fit a pic so decided to go to surface mount, so much simpler, that link was perfect, will give that a go tomorrow...fingers crossed...
cheers
Dazza
No problem Darren,
I don't blame you for wanting to solder and drill as few wires/holes as possible. I f i was in your shoes, I would be the same.
Glad the link helped.
Thanks for letting us know.
Surface mount is the future :D
Its so much easier to get good looking boards and also quicker to do once you have the knack.
Great tutorial available free from here.
http://www.001tech.co.uk/Forum/viewtopic.php?f=18&t=60
Darren.Smith
Flowcode V4 User
totally agree ben, they are already starting to phase out the older dil type ic's and replacing them with surface mount only, a bit of a pain for older designs but much easier to work with in the long run, i am surprised matrix does not do a plug in board for the eb006 programmer to take the new surface mount devices.....
