Hello forum,
can anybody help me with an issue I have programming 18F4455? I want not to use the port B due the interrupt inputs I need, so I tied the LCD to the port A and also test it on port C. With a simple program, just a "hello" printout, only on port B worked. I also connect pull up resistors. In simulation (flowcode V5) everything is fine...On port C I change the pin C3 with C6 because C3 doesn't exist. What am I doing wrong?
Sakis
LCD on port other than B...
Re: LCD on port other than B...
PortA Pin4 is an open collector type pin and as such cannot be used to source current. A pull up resistor around 4.7K between this pin and the +v supply rail should allow the pin to function correctly.
PortC has pins C4 and C5 dedicated to the USB hardware, these pins cannot be used as outputs.
Would PortD be a possibility, no complications with using this port.
Thank you Ben for your reply! I tied pull up resistors on port A but no change. Any way I used this PIC type because I need 2 8bit inputs, an LCD screen and an interrupt input but it seems to be a bad choice...Maybe I will use multiplexing to do that.
Thank you again
sakis
Thank you again
sakis
