how to print a decimal value in lcd
rags
Has thanked: 1 time
Post by rags »
hello sir,
what function should i use to print a decimal value
for eg a=7
b=2
c=a/b and in lcd when i use print number(c) command i want the lcd display to show 3.5 but float is not supported pls help
ragesh
Re: how to print a decimal value in lcd
Hi ragesh,
I have moved topic so we can keep Tips section for posting tips, and not starting topic with a question question.
As for the Decimal point, take a look here:
http://www.matrixmultimedia.com/mmforum ... 326#p20298
There are two replies that should be able to help you.
With your example, I would 1st multiply a by 10 so you have got 70/2
Reason for that is with pic maths if not using float it will disreguard any remainders since bytes and intergers are whole numbers only.
so 7/2 = 3
not 3.5
rags
Has thanked: 1 time
Post by rags »
hello sir,
as i am using flowcode for AVR can u please guide to a topic that deals my question with AVR
thank you!!
You will be able to use import function from File/ Import to import pic versions of Flowcode.
Or do you mean you want this thread moved to Flowcode V4?
What version of AVR do you have (Help, About Flowcode menu)?
If the version is too early then you will not be able to import successfully.
rags
Has thanked: 1 time
Post by rags »
sir,
i use flowcode v4..i have imported it..but i want to display a mathematical calculation in decimals not an ADC value..
say 7/2..i want 3.5 to be displayed in my LCD display
Instead of adc, your using your own variables.
That flowchart was to show you a method of how it can be done, then you just create your own flowchart once you have learned the principles.
For that method you need to learn how Left$ and Right$ work.
Then as stated in my previous post
so 7/2 = 3
not 3.5
So 70/2=35
Convert to string then use Left$ and Right$ to separate the two digits.
Alternatively you can use the Mod function to separate the digits.
e.g
Digit_0 = Voltage MOD 10
Digit_1 = Voltage / 10 MOD 10
If your still stuck then I can post a flowchart to demonstrate both methods.
See if you can have a go first and post a flowchart, as that is a good learning method.
Hi rags,
I have altered flowchart from link I had posted, to display the result with a decimal point.
It may not be perfect, but it should do what you’re after.
a div b v1.fcf
(8.5 KiB) Downloaded 485 times
(75.89 KiB) Downloaded 4189 times
rags
Has thanked: 1 time
Post by rags »
hello sir ,
thanks for your response , thanks a lot!
i tried and have come up with a better and very easy solution.
what i did was..
a=7
b=2
c=7/2
all variables are FLOAT,
initialze string variable str. then use string manuplation[ str=floattostring(c)] ; now in lcd print string--> str and the its accuracy is upto six decimals!
thank you,
reagrds
ragesh
rags
Has thanked: 1 time
Post by rags »
sorry small typing mistake in previous post
it is c=a/b
and its NOT
c=7/2
rags
Has thanked: 1 time
Post by rags »
i have attched a sample file.
i have used at,ega32 MCU
print_adecimal.fcf_avr
(5.5 KiB) Downloaded 471 times
