16f1938 port output masking inop
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: 16f1938 port output masking inop
I can't understand what did you want to mean ? Can u tell bit more detail?
- Has thanked: 175 times
- Been thanked: 173 times
the problems is, when the program first starts i like to initialize unused pins high, so i use output masking with the output icon, this is what fails, when i mask the bank pins they dont go high,..... have to command all unused pins one by one to make them have the correct output state on this chipI can't understand what did you want to mean ? Can u tell bit more detail?
Hi Brandon,
Please can you post a program that demonstrates the issue and we will look into it for you.
- Enamul
Hi Brandonb,
I have tried to replicate the situation you have described but didn't get that...I am attaching here a FC. Can you have a look and tell is that the condition you are talking about and which you are getting problem?
At the same time you please have a look at the post for minor fix if you have not done already...
http://www.matrixmultimedia.com/mmforum ... 46&t=10669
Thanks,
Enamul
Thanks,
Enamul
- IN_MASK.fcf
- (11 KiB) Downloaded 314 times
