Help for RFID??
ilusaud
Has thanked: 2 times
Help for RFID??
Post by ilusaud »
Hi guys, recently i lost my LCD board, so i have to continue my project without it.
The problem is in my RFID board is when I tune the rfid board capacitor it always shows me stable red and green led. So is that a problem in rfid board.
And can i write program for card detection without lcd. can anybody help me out
ilyaz
Re: Help for RFID??
Hi ilyaz, This is the second post I have moved from The Tips & Tricks section.
Tips is not for asking for any help or support.
Please see:
http://www.matrixmultimedia.com/mmforum ... =26&t=8756
I have moved post to Eblocks since your first question is related to RFID board.
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: Help for RFID??
Post by JohnCrow »
Hi ilyaz
With the RFID board, you should only see the red or green led on one at a time
These are a few basic things you can try.
If you move the tag over the antenna you will get the leds alternating, as the tag goes in and out of the detection area.
They are not actually both on at the same time, though it may look like it because of the time it takes your eyes to see the led go out. (Persistance of vision)
Going by the e block data sheet
Red flashing = ant needs tuning
Red stable = ant tuned but no tag detected (tag could be faulty or wrong type)
Green stable = ant tuned and tag detected
I have not had to adjust the tuning on my board since i bought it
Have you tried a second tag, or a different tag i.e mifare or icode .
Have you checked the jumper settings on the board match the pic you are using - see data sheet.
Do you mean you have lost the LCD i.e you dont know where it is or do you mean it has failed.
Well without the lcd you wont have any way of giving feed back that the card has been detected.
You could use the LED eblock to give an indication or if you are using it as a card entry system for example,just activate a relay or solenoid when the card is present.
