In v5, this switch control the light of the example has problems:
The simulation is good; But download to 16f887 chip, not the correct operation!
In v4,do not have any problem!
Please help me!
V5 bug
Re: V5 bug
There is a slight bug in the switch and switch bank components for Flowcode v5 and v5.2.
Please ensure you are using the latest version (5.2) and then see here for the current set of updated files.
http://www.matrixmultimedia.com/mmforum ... 46&t=10669
Let me know how you get on.
Re: V5 bug
I know the problem! English environment is no problem! I am using Chinese interface, will have the above problems! Chinese environment that bug! You can try Chinese interface case!
Thank you!
Thank you!
Re: V5 bug
Please can you post up your program so we can have a look into the problem.
Also please can you join the v5 forum so you can post your v5 related questions in the appropriate place.
http://www.matrixmultimedia.com/mmforum ... =46&t=9958
Re: V5 bug
In the Chinese interface open this example, and download to chip problems will occur! You try!
- switch-led.fcf
- (12 KiB) Downloaded 333 times
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: V5 bug
Hi there. Thanks for letting us know about this.
I have looked at the C code generated for this when I select both Chinese and English - apart from comments the C code is identical.
Could you perhaps post your generated C code with the working and non-working version, and also the HEX and ASM files generated too if you could? This will help us narrow down what the problem might be.
Cheers,
Jonny
Cheers,
Jonny
Re: V5 bug
In the Chinese and English in the interface of the generation of C code and ASM code is indeed the same! But their HEX file but have very big difference. The key is to download the chip results but not as after! The English can be a very good operation. The Chinese is really not line! You download to chip try! (16 F877 is the same problem). Thank you! ((the Chinese FlowZHCN. DLL Have a problem.)
- switch-led(chinese).HEX.txt
- (908 Bytes) Downloaded 315 times
- switch-led(English).HEX.HEX
- (912 Bytes) Downloaded 304 times
