read byte/byte on flowcode
jeannoor
Post by jeannoor »
Hello everyone,
I have very big problems to write the code to read a byte that arrives on port A (B3, for example) and display it on an LCD
I have a code they do but the assembler problemme is that there are n has not adapted Flowcode
bits0
    clrf codlue
    movlw .8
    movwf cmpt
;read 1 octet
lec_bit0
    call clk
    btfss PORTA,3
    goto non
    bsf STATUS,0
    rlf codlue,f
    decfsz cmpt,f
    goto lec_bit0
    goto wite_onEeprom
non
    bcf STATUS,0
    rlf codlue,f
    decfsz cmpt,f
    goto lec_bit0
clk
    bsf PORTA,0
    nop
    bcf PORTA,0
    nop
    return
wite_onEeprom
		   movfw lencode
		   movwf EEADR
		   movfw codlue
		   movwf EEDATA
		   BANK1
		   bcf EECON1,EEIF
		   bsf EECON1,WREN
		   movlw 0x55
		   movwf EECON2
		   movlw 0XAA
		   movwf EECON2
		   bsf EECON1, WR
		   incf lencode
		   decfsz compt,f
		   goto bits0
ps : codlue mean the readen data
please helpe to convert this code to flowcode because it a probleme on compilation to .hex
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: read byte/byte on flowcode
Post by Enamul »
Can you please tell the details of the code what you want to do?
It's tough to recover bcz of language..it seems the code will be easy in Flowcode..
Enamul
Enamul
University of Nottingham
enamul4mm@gmail.com
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Post by Spanish_dude »
You want to (serial) read 8 bits on PORTA.3, store them into a variable, write that variable in the EEPROM and increase 'lencode', right ?
Nicolas
Enamul
Post by Enamul »
Thanks Nicolas..
I have had a better look at the code and re-programmed that in FC...
Hope this will help :)
Enamul
serial_data_EEPROM.fcf
(16 KiB) Downloaded 258 times
Enamul
enamul4mm@gmail.com
