frequency meter tmr2 blunder
brandonb
- Has thanked: 175 times
- Been thanked: 173 times
this frequency meter works great, however i discovered something odd--> this only works accuratly with a tmr2 frequency of 1000 hz, for example reading 5khz input the meter reads 5Khz but if i set tmr2 interrupt to 250hz it reads 4988 hz instead,.... so for kicks i tried a 16.384Mhz crystal instead of internal osc for a lower even tmr2 interrupt freq, i tried 1000 hz again and it was spot on, then i tried 62hz tmr2 interrupt frequency, it was 30 hz low at 4970 roughly,......
i would have figured that using a low tmr2 interrupt frequency my interrupt on pin input frequency would have been more accurate than at a high frequency tmr2 interrupt since at a high interrupt speed there is less time to service the interrupt on pin macro, but that theory was proven backwards(why did this happen?)
- freq_meter_v1.0.00.fcf
- (18.79 KiB) Downloaded 402 times
Gary Freegard
- Has thanked: 1 time
- Been thanked: 30 times
Re: frequency meter tmr2 blunder
Hi Brandon
Had a look at your program, and was getting a bit confused by the results.
Have written my own version, differences from yours are:
. So after a look at the datasheet I saw that it was possible to use a timer as a counter with an external input. In the Timer_Enable and Timer_Disable macros the C code is used to enable and disable the counter. Also in these macros is an output to port A for timing measurements/calibration.
The macro Frequency is used to read the counter and reset it with the C code, and then display the result.
Using the output on port A I have got the following results, freq is the timer2 int and time is measured on port A
If a higher accuracy is required then use the highest frequency possible, as this will allow finer calibration.
So for the above reading, target should be
Gary
- uses 16f877a
the timer enable and disable are in macros
LCD update is in a macro
uses timer1 as counter
main is used to initialize and has an empty loop
not using variables to control count etc
has an output on A0 for calibration (1sec)
- freq time
10000 0.9986
1000 0.9986
500 0.9975
250 0.9954
- 10014
1001
501
251
Gary
- frequency.fcf
- (19.83 KiB) Downloaded 386 times
