http://microcontrollershop.com/product_ ... ts_id=4406 I was wondering if the graphic LCD in this link will work with flowcode5
Thanks,
Danny
Graphic LCD question
DannyBerry
- Has thanked: 11 times
- Been thanked: 1 time
- petesmart
- Has thanked: 187 times
- Been thanked: 140 times
Re: Graphic LCD question
Hi Danny,
I have not had any experience with the display that you have indicated in your post, however I have had experience with displays from 4Dsystems
http://www.4dsystems.com.au/
These are the type that MM have in their EB series boards http://www.matrixmultimedia.com/product ... PHPSESSID= which you may have already seen..
If you do not want the display mounted on the E-block, then you can purchase the display separately from 4D systems. If you do take this route, remember to purchase the serial programming cable. Unfortunately this is a separate item but it is very handy in learning and about and configuring the display.
I purchased a 4D Systems display before MM came out with E-block, and was pleased with the outcome.
All the best,
Pete
All the best,
Pete
sorry about that Chief!
