18f2685 internal osc with pll
brandonb
Has thanked: 175 times
Been thanked: 173 times
Post by brandonb »
im trying the get the 18f2685 set to 4 meg internal with 4x ppl, shooting for 16Mhz internal osc but can seem to get it to work as it default to 4Mhz... i set osctune to 0x40 (01000000) and osccon to 0x6e (01101110), what am i doing wrong and can you please explain it to me?
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: 18f2685 internal osc with pll
Post by kersing »
brandonb wrote:im trying the get the 18f2685 set to 4 meg internal with 4x ppl, shooting for 16Mhz internal osc but can seem to get it to work as it default to 4Mhz... i set osctune to 0x40 (01000000) and osccon to 0x6e (01101110), what am i doing wrong and can you please explain it to me?
Have you set the configuration (FOSC3:FOSC0) bits in CONFIG1H correctly? (Open the chip configuration in flowcode, set oscillator to Internal Oscillator Block mode)
Setting osccon to 0x6e means you are trying to write to read-only bits of the register, 0x62 seems more appropriate.
― C.S. Lewis
brandonb
Post by brandonb »
thanks for checking it out but that didnt work either :?: here is the flowchart so far https://dl.dropbox.com/u/10367218/flow_ ... osccon.fcf its a bit too large to post
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
Hi!
Flowcode5
Microcontroller: Pic18F2620
internal oscillator8MHz and 4Pll
Beginning of the program:
 C code:
 osccon = 0x70;/ / 8MHz
or
osccon = 0x60;/ / 4MHz
osctune = 0xC0;
brandonb
Post by brandonb »
C code:
or
osctune = 0xC0;
right on, that works perfect
