KeyPad detects it and transmits TX Output
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
Post by Monie Jacobsen »
Two all C programøre
When a key is pressed the 16F84 micro detects it and transmits
the ascii character for that key on a 1 wire rs232 interface.
Are there anybody who would please help me with the codes here under?
And please after this make a HEX file or Flowcode 5.2 for PICmicro file.
I do not know how to do it.
I hope it is the wright place i ask this question
The original C codes (KeyPad 4x4) Se http://www.viddata.com/keypad_hardware.htm
I have bought and want to use KeyPad 4x3 Se: http://www.matrixmultimedia.com/datashe ... 4-30-1.pdf
I would be very happy if somebody will converter the codes to KeyPad 4x3.
So i could use KeyPad 4x3 together with Flowcode 5.2 for PICmicro
Best regards
Monie
Best Regard
Monie
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: KeyPad detects it and transmits TX Output
Post by Enamul »
You can have a try with the attached program and let me know how its going..
Enamul
KEYpad_Rs232.fcf
(13.5 KiB) Downloaded 528 times
Enamul
University of Nottingham
enamul4mm@gmail.com
Monie Jacobsen
For Enamul
Thank you very much
It was just what I was looking for :-)
I make some tests and returns back!
Best regards
Monie
Best Regard
Monie
Monie Jacobsen
For Enamul
How can I print the key number forom Display Port D on ECIO40P
When the signal coming from Keynumber PIC16F628
Please see the 2 attached files
Would you please give me an example of output at ECIO40P display?
RS232KeyOutputDisplay.fcf
PECIO40P
(11.5 KiB) Downloaded 512 times
KEYpad_Rs232.fcf
PIC16F628
(13.5 KiB) Downloaded 496 times
Best Regard
Monie
Enamul
Post by Enamul »
Here is an example of ECIO40P display program...You have to put LCD start macro first...
Note: What you want to do please explain in details I can help you then..
Are you trying to read keypad data using PIC16f628 and send that using RS232 and receive by ECIO40P and display that in LCD which is connected to PORTD?
Please let me know!!
Enamul
(10 KiB) Downloaded 500 times
Enamul
enamul4mm@gmail.com
Monie Jacobsen
To Enamul
Sorry, I meant when number was the election of PIC628 (independent entity) then with a wire over to ECIO40P RX input
See the picture below ilustrationen
Yes
I trying to read keypad data using PIC16f628 and send that using RS232 and receive by ECIO40P and display that in LCD which is connected to PORTD?
Illustration
(157.41 KiB) Downloaded 4961 times
Last edited by Monie Jacobsen on Mon Jul 30, 2012 7:34 pm, edited 1 time in total.
Best Regard
Monie
Enamul
Post by Enamul »
HI,
Ok...The idea is what I said..
Here is the program..you have to use RS232 component in both transmitting and receiving PIC...
Enamul
(9.5 KiB) Downloaded 535 times
Enamul
enamul4mm@gmail.com
Monie Jacobsen
To Enamul
It works very well
I will here from Denmark tell you many thanks for your great help and your great patience.
Good Evening to you and your family.
OK - This command I did not know
(2.69 KiB) Downloaded 7335 times
Best Regard
Monie
dazz
Has thanked: 474 times
Been thanked: 458 times
Post by dazz »
Hi monie
Can you sign up to the v5 forums please
Dazz
Monie Jacobsen
To Enamul
I am sending you a private PM (Send private message)
And OK to dazz;-)
Best Regard
Monie
