AVR compiler errors
stasiks
AVR compiler errors
Post by stasiks »
There was a need for the Programming all was good while the PWM launched, during compilation appear in the following problem:
/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Enable_Channel_1':
/AVR\AVR_CAL_PWM.c:671: error: 'COM0A0' undeclared (first use in this function)
/AVR\AVR_CAL_PWM.c:671: error: (Each undeclared identifier is reported only once
/AVR\AVR_CAL_PWM.c:671: error: for each function it appears in.)
/AVR\AVR_CAL_PWM.c:676: error: 'COM0A1' undeclared (first use in this function)
/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Disable_Channel_1':
/AVR\AVR_CAL_PWM.c:702: error: 'COM0A1' undeclared (first use in this function)
/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Set_Duty_8Bit_1':
/AVR\AVR_CAL_PWM.c:845: error: 'OCR0A' undeclared (first use in this function)
/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Set_Duty_10Bit_1':
/AVR\AVR_CAL_PWM.c:1121: error: 'OCR0A' undeclared (first use in this function)
Search forum but did not find anything in google could not do anything useful to tell.
From the C language do not understand anything so I'm desperate please help, Thanks
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: AVR compiler errors
Post by DavidA »
Could you post a Flowchart and the generated c code which exhibits this problem
stasiks
Post by stasiks »
Thank you that answered so quickly, here is Flowcharts and the generated c code.
Thank you.
Fan.fcf_avr
Flowcharts
(12.5 KiB) Downloaded 839 times
Fan.c
c code
(30.98 KiB) Downloaded 826 times
I will try and get this sorted in the main PWM CAL file. For now you can fix the issue by using this workaround.
Click On Build -> Project Options.
Tick the box "Use supplementary code" and then click the button "Supplementary code"
In the top window paste the following section of code.
#define COM0A0 COM00
#define COM0A1 COM01
#define OCR0A OCR0
Click OK twice and the program should now compile correctly.
Let me know if you have any problems.
stasiks
Post by stasiks »
Thank you very much, everything did and everything was successful.
Thank you very much :D
vlad1451
Has thanked: 1 time
Post by vlad1451 »
Hello. Prompt, and it is possible to involve all PWM channels in the controler. If I am not mistaken at Mega16/32 their 4 channels.
vlad1451
Has thanked: 1 time
Post by vlad1451 »
Really there is no opportunity to involve all 4 channels?!!!
I have now fixed this in v6 for the ATMEGA32 which only showed 3 of the 4 available channels. Do you need this fix in v5 or v6?
vlad1451
Has thanked: 1 time
Post by vlad1451 »
v5
Ok this updated definition file should resolve the problem.
ATMEGA32.fcd
(10.11 KiB) Downloaded 819 times
Let me know how you get on.
vlad1451
Has thanked: 1 time
Post by vlad1451 »
Thanks.
vlad1451
Has thanked: 1 time
Post by vlad1451 »
In case of compilation gives out the same error:
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Enable_Channel_2':
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c:671: error: 'MX_TCCR_X' undeclared (first use in this function)
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c:671: error: (Each undeclared identifier is reported only once
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c:671: error: for each function it appears in.)
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c:671: error: 'MX_PWM_COM0_X' undeclared (first use in this function)
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c:676: error: 'MX_PWM_COM1_X' undeclared (first use in this function)
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Disable_Channel_2':
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c:702: error: 'MX_TCCR_X' undeclared (first use in this function)
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c:702: error: 'MX_PWM_COM1_X' undeclared (first use in this function)
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Set_Duty_8Bit_2':
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c:845: error: 'MX_DUTY_REG_X' undeclared (first use in this function)
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Change_Period_2':
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c:977: error: 'MX_PRESCALE_X' undeclared (first use in this function)
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Set_Duty_10Bit_2':
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c:1121: error: 'MX_DUTY_REG_X' undeclared (first use in this function)
Test project on 4 canals:
Flowcode1.fcf_avr
(8.5 KiB) Downloaded 702 times
If you go into the project options, enable supplementary code and then paste the following code into the top window of the supplementary code then the program should compile as expected.
#define OCR0A OCR0
vlad1451
Has thanked: 1 time
Post by vlad1451 »
Hello, I inserted this code and still gives out an error:
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Enable_Channel_4':
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Disable_Channel_4':
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Set_Duty_8Bit_4':
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Change_Period_4':
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Set_Duty_10Bit_4':
Flowcode1.fcf_avr
(9 KiB) Downloaded 627 times
Many thanks. I have managed to track down the issue and the attached definition file should solve all the problems, no need for the supplementary code workaround any more.
ATMEGA32.fcd
(10.19 KiB) Downloaded 734 times
vlad1451
Has thanked: 1 time
Post by vlad1451 »
Everything works, many thanks. It is pleasant to deal with you. I apologize for my English, I from Russia.
