Is this GPS would be usable with Flowcode v5?
For users of Matrix Multimedia Electronics software to discuss projects, circuits and any other electronics concepts.
Speedy2k
Has thanked: 2 times
Post by Speedy2k »
https://www.sparkfun.com/products/465?
I would like to know if this GPS is usable with flowcode, i am looking at it because of the 5 volts supply it needs, about every other one i have seen are 3.3 volts! If anyone have a better option let me know thanx a lot!
Re: Is this GPS would be usable with Flowcode v5?
Hi Speedy,
The module should work fine with Flowcode but be careful the supply voltage is 5V but the output to the micro seems to be at 2.85V.
You could use a buffer IC with open collector style outputs and this way you can convert the signal back to the micro up to 5V by using a pull up resistorto VCC on the buffer output.
