Touch Sensitive Switch
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Post by JohnCrow »
Touch Sensitive Switch.
While browsing a component website I came across an IC shown as a 2 Channel touch switch.
It was under a couple o quid so I added a couple to the order to have a play with.
When it arrived it as an 8pin dip device with a small sticky label on the top. I immediately pealed this off to see what the device was.
It turned out to be a 12F683 PIC.
The code was protected (as expected) so I was not able to read it to see how the device was programmed :(
I wired it up on the bread board to test it out, and it works exactly as shown in the specs.
I built it up on a small PCB with a couple of chrome touch sensors.
The sensors are screw in covers to fit in a countersunk screw from the local diy shop.
Because they are chrome plated it was not possible to solder them and the thread is not long enough to use a nut and connector on the back.
The touch inputs are use a 1M-ohm pull up resistor to Vdd.
I made the connection by having a couple of bent over bits of wire under the dome, and connected these to the pcb.
The switches allow the sensors to be set to either latch or momentary.
Pins 4 & 5 on the chip are connected to the switch common termnals, with pins 1 & 2 on the switch to Vdd or Gnd
The screw terminals are left to right
Vdd, Gnd, Output1, Output2
The device will work on any voltage from 2.5V to 5V.
This makes it usable with PIC, AVR, ARM or Raspberry Pi without the need for an external voltage regulator.
Circuit Diagram
Circuit Diagram
Breadboard Prototype
My breadboard has a PP3 battery and 7805 regulator underneth it.
The 4mm binding posts are connected to the regulator input and the spring termnals to the regulator output (5V).
The switch on the top of the case turns off the battery.
The blue & yellow wires at the bottom of the photo are the touch inputs.
It will actually switch by touching the insulation as well as the metal contacts.
Touch Switch
Touch Switch
Touch Switch.JPG (115.15 KiB) Viewed 13825 times
The sensors are actually held on the board by a blob of epoxy resin on the back.
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Re: Touch Sensitive Switch
Post by Spanish_dude »
Probably some AD conversion using the PIC.
Have you tried probing the inputs ? See what the signal looks like.
If you know what happens when you touch the switches you could probably make your own program.
Nicolas
Steve001
Has thanked: 460 times
Been thanked: 523 times
Post by Steve001 »
sorry if this has posted twice .
Looks like a good project john
I was going to have a play with touch sensors but time evades me :(
Have a look here there is some code examples too
http://www.bytecraft.com/Touch_Sensitive_Switch
steve
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
JohnCrow
Post by JohnCrow »
I do intend having a look at trying to replicate it it flowcode sometime.
Dont think it will be too difficult, but like Steve its finding time for all these projects.
STibor
Post by STibor »
Simple programs and circuits.
vizor1 2.fcf
(8 KiB) Downloaded 545 times
vizorpcb.PDF
(158.05 KiB) Downloaded 578 times
vizorsch.PDF
(16.97 KiB) Downloaded 726 times
JohnCrow
Post by JohnCrow »
Thanks STibor
That looks interesting.
I'll try your program out when I get chance.
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hi all!
Here are some related projects:
http://www.pcbheaven.com/circuitpages/P ... ch_Button/
http://www.pcbheaven.com/circuitpages/P ... _Function/
Very interesting. It would be nice if someone could translate them into FC I have no experience with C or assambler.
Best regard
Jorgen
JohnCrow
Post by JohnCrow »
This is a simple flowchart and circuit to use the touch switch board with an ECIO
With the slide switch to the left, the channel latchs
With the slide switch to the right the channel toggles.
For example if Sensor 1 is set to latch and Sensor 2 to toggle.
Touch Sensor 1. It will show Sensor 1 Touched. Then touch Sensor 2, it will show Both Sensors Touched.
To unlatch Sensor 1 touch it again.
E-Blocks Setup
E-Blocks Setup
Simple touch.fcf
(12.22 KiB) Downloaded 521 times
Post by jgu1 »
Hi John! :D
Very interresting. I will test it this evening.
Maybe something I have misunderstood, but where can I find the input for the slideswitch in the program.
Do you have tied the input to ground with a resistor,if you have is 1M ok :?:
Best regard
Jorgen.
JohnCrow
Post by JohnCrow »
The slide switch is not in the flowcode program.
They connect pins 4 & 5 on the 8pin device to either 5V or Gnd.(This sets it to latch or toggle)
The 8pin pic was bought as a touch switch device. See the first post in the thread.
The touch inputs have a 1M-ohm pull up to the +V line.
Post by jgu1 »
Thank´s John :D
