switch to ground
donald
Been thanked: 3 times
switch to ground
Post by donald »
Hello to all.
How do light up an led shutting circuit from uC at ground?
When the button is pressed to be ignited led.
Thank you in advance!
switch to ground.fcf
(12 KiB) Downloaded 292 times
(12.51 KiB) Downloaded 1562 times
Re: switch to ground
Here is a quick program that will do what you want. I have basically done the same program twice, the first loop I used the switch and LED components via component macros and in the second loop I used I/O icons.
SW_LED.fcf
(13 KiB) Downloaded 312 times
donald
Post by donald »
Good evening Benj,
Thank you very, very much, works great, thank you once again.
