CAN & RF board connection to ECIO-40
st9905
Flowcode V4 User
Post by st9905 »
I'm working on a project where I will connect a RF board and a CAN board to the same ECIO-40.
AS far as I understand I can change the pin configuration for the EB063 RF board, but only the CK pin for the EB018 CAN board.
How should I connect the CAN and RF boards to the ECIO-40?
If I like to use the INT function, can I use the RXINT or do I need to use any of the B0..2INT functions in flowcode?
Since both boards are using the SPI protocol I guess that I can use the same SPI pins and just change the CS pin.
I have attached a file with the pin data I have found.
I'm using Flowcode 5.
Erik
CAN and RF pin config.xls
(18 KiB) Downloaded 216 times
Erik
Re: CAN & RF board connection to ECIO-40
Hi Erik,
Yes this should work correctly as long as you use two CS pins, one for each of the comms modules and then bus together the SPI interfaces.
The INT pins can be fed back to the INT enabled pins if you want interrupt functionality. Alternatively you could use the Port interrupt which fires whenever a signal on pins RB4-RB7 changes state.
