I am using tone decoder chip and need sum of D1-D4
I know it should be something like D1+(D2*2)+(D3*4)+(D4*8)
I need to store this to variable to see 1 of 16 decoded outputs
I am new to C programming and don't know sytax
How do I sum 4 bits to variable
Re: How do I sum 4 bits to variable
That looks fine to me as long as your values are all 1 to begin with. You can also use shifts which should be a less processor intensive then a multiply.
Data = (D1 + (D2<<1) + (D3 << 2) + (D4 << 3));
You could also use a Logical OR rather then a addition but I don't really think this matters too much.
Data = (D1 | (D2<<1) | (D3 << 2) | (D4 << 3));
If the data maybe isn't 1 then you could maybe do this.
Data = 0;
if (D1)
Data |= 1;
if (D2)
Data |= 1 << 1;
if (D3)
Data |= 1 << 2;
Data = 0;
if (D1)
Data |= 1;
if (D2)
Data |= 1 << 1;
if (D3)
Data |= 1 << 2;
markus747
- Has thanked: 26 times
- Been thanked: 2 times
Still don't get it.
Please look at what I have.
it still doesn't seem to see sum of b.0 b.1 b.2 d.7
- lateral cleaner_1.fcf
- (14.42 KiB) Downloaded 698 times
markus747
This one is even better.
- lateral cleaner_2.fcf
- (14.69 KiB) Downloaded 713 times
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Here is the corrected code..what Ben posted don't need to put in c code box rather in calculation box is ok. But you need to read input..anyway I have corrected the code.
- lateral cleaner_3.fcf
- (18.5 KiB) Downloaded 718 times
- Dan81
- Been thanked: 60 times
Hello Markus
There no "special" fonction on RB3
if you can use RB3 for "D4", there will not be any calculation to do.
(Or I don"t understand the aim of your calculation. )
Daniel
Daniel
- lateral cleaner_4.fcf
- (16.28 KiB) Downloaded 693 times
