HEX with interrupt in PPPV3 won't work, pickit3 does
Jaspervdw
Been thanked: 3 times
Post by Jaspervdw »
I'm making a project in MPLABX with XC8.
I'm using follwing code:
#include <xc.h>
#define _XTAL_FREQ 19660800
#pragma config CONFIG1 = 0x2FF2;
#pragma config CONFIG2 = 0x3FFF;
void interrupt timer0(){
    INTCONbits.T0IF = 0;
    PORTC = 0X77;
void main() {
    //TImer 0
    OPTION_REGbits.T0CS = 0;
    OPTION_REGbits.T0SE = 0;
    OPTION_REGbits.PSA  = 0;
    OPTION_REGbits.PS2  = 1;
    OPTION_REGbits.PS1  = 1;
    OPTION_REGbits.PS0  = 1;
    TMR0 = 0;
    INTCONbits.T0IE = 1;
    INTCONbits.GIE  = 1;
    TRISC = 0x00;
    PORTC = 0x01;
    while(1){
        //PORTC = TMR0;
        //__delay_ms(499);
When I program the pic with the PPPV3 en the E-block board, the program won't run.
When I program the pic with the pickitt3, then put the PIC back in the E-block, the program run's correctly.
Anyone an idea?
Re: HEX with interrupt in PPPV3 won't work, pickit3 does
That seems odd, which chip are you using?
Jaspervdw
Post by Jaspervdw »
Hey,
I'm using the PIC16F887. I included the hex file as example.
001_-_Blinking_Led.X.production.hex
(396 Bytes) Downloaded 584 times
Jaspervdw
Post by Jaspervdw »
Sorry,
I does does work, I only have to reset the circuit after uploading.
