Microcontroller development board version3 software
For users of Matrix Multimedia Electronics software to discuss projects, circuits and any other electronics concepts.
Desdewit
Has thanked: 25 times
Been thanked: 11 times
Post by Desdewit »
Hi Guys
Are there any old or upgraded software available for a PICmicro Microcontroller development board version3 HP488-00-3.
Does it have any other function on the board except for running the usb?
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: Microcontroller development board version3 software
Post by Enamul »
Here is the link for USB drivers..you can check whether you have the latest one..
http://www.matrixmultimedia.com/lc_index.php?p=17
Enamul
University of Nottingham
enamul4mm@gmail.com
Desdewit
Post by Desdewit »
Is it possible to re-program the USB interface chip on my development board?
Enamul
Post by Enamul »
You can PM David about that as only MM guys can tell you that.
Enamul
enamul4mm@gmail.com
Desdewit
Post by Desdewit »
Hi Enamul
Thanks for the reply, I realy hope someone can help me with this. :cry:
A few days ago my power supply for my V3 development board over heated & stopped working for unknown reasons. After replacing the power supply my programmer was working again with no obvious problems but for some reason if I program my old working rs232 test program with Hardware RXint & Software RB0Int the software side give me strange errors.
If I send a byte via Pc for instance Dec 1-80 the pic will reply with the correct value but as soon as I send something like 90 it reply with 218, 100 reply with 228 or Ascii A –J will be correct but ascii K will reply with <(CB)> and ascii L will reply with <(CB)>.
I’ve also tested the following.
Test the software on different pins with and without interrupts.
Test and replaced max 232 chip (Both channels working correct)
Tested & replaced different versions of pic’s
Tested both rs232 ports and serial software on two different pc’s
Used flowcode on a different pc to load the program
Could the problem be the usb interface chip on my development board not programming the correct way. (It does feel a little hot sometimes)
The strange thing is that only the software port is giving problems.
RS232 Test.fcf
(14.14 KiB) Downloaded 681 times
Enamul
Post by Enamul »
HI
I have looked through the code and the code is fine know issue is there. There must be something wrong with the hardware. From PC are you sending string or character; what is the length of wire?
Enamul
enamul4mm@gmail.com
Desdewit
Post by Desdewit »
Hi Enamul
I'm sending 1 Character at a time to test over a 1m serial cable.
The problem is that I know my original program was working and was sending and receiving multiple bytes without a problem.
The receive problem only started after the suspected short, but why only on the software part of the rs232?
Enamul
Post by Enamul »
You mean after short only software RS232 causing problem...hardware usart using RXint works fine?
Enamul
enamul4mm@gmail.com
Desdewit
Post by Desdewit »
Yes, So far I can not find any other problems.
That's why I think it might be the program not loading correctly.
Enamul
Post by Enamul »
I don't think that. Because I was using RS232 with RB0 int and it's happen to miss some data because of long distance but your distance is only 1 m. So confusing..You know later on I have move to CAN and CAN is absolutely reliable.
Enamul
enamul4mm@gmail.com
Desdewit
Post by Desdewit »
Do you know if microchip has cheap programmers that can program the same chips as the V3 Development board or the EB006?
I urgently need to replace my programmer but our local supplier can only get me a matrix EB006 early in January 2013
:( :x :cry:
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
You can program the Eb006-00-7 and above directly using the PICKit2/3 with the ICSP header that is on the board, for the HP488 v3 and EB006-00-6 and below you will need an adapater to change the ICSP on the PICKit2/3 to an RJ45 connection to plug into the RJ45 socket on the boards.
Desdewit
Post by Desdewit »
Hi David
I'm going to get myself a pickit 3 but would still like tor repair my HP488 v3 development board.
Do you know if I can still get a replacement chip with firmware for the HP488 v3 board.
DavidA
Post by DavidA »
Yes that will be possible, please email <sales>@<matrixmultimedia>.<com> and explain you need a PPP chip for a HP488 v3 dev board, they will be able to advise
