convert to string dspicV5.4
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
Post by saschech@gmx.de »
In a new projekt i want print on the lcd var. uint 65500.
The lcd only Support int (go to 32767);so I convert the uint to string,
The lcd Show on hardware: uint 65500 >> to string >> lcd 32732.
My Problem is,it work on Simulation.
If I print string "65500" , Show correkt on my Hardware,so I think the convert-macro work not ok
on Hardware.
regards wolfgang
saschech@gmx.de
Has thanked: 1 time
Re: convert to string dspicV5.4
all return,after a Long search :
I read the fram FM25V5 in the READ-mode dos not read bit8 korrekt.....
I use the FSRD mode and all work ok on my Hardware
Regards Wolfgang
AN302.pdf
(79.2 KiB) Downloaded 231 times
