Morning all,
How do you set the UART channel to use with the Zigbee module? Looking at the Ext Properties of the module I can't see where one would choose the UART channel.
many thanks
Sefi
Setting UART channel to use with Zigbee module
Re: Setting UART channel to use with Zigbee module
Worked out how to do it. Please ignore.
It involves changing or customising the code. It would be nice to have this as a menu item. Maybe MM will add this to the wish list.
The solution is fairly easy within FCv4.0 but in V5 with the addition of the CAL layer I can't work out where this should be done. So if anyone can help I'd be grateful.
many thanks
Sefi
many thanks
Sefi
