PWM using Flowcode V5
weatherman5
Post by weatherman5 »
I am running the free trial of Flowcode V5 and want to know if I can use it to bring an led from off to full brightness over say 0.5 second ?
I think this would be done using PWM which is built into the PIC I am using 16F628.
If I know it can be done I can purchase the full program.
Thanks, Dave
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: PWM using Flowcode V5
Post by Enamul »
It can be done in FCv5 very easily. If you want we can send you hex file so that you can test and decide to buy professional version.
Enamul
University of Nottingham
enamul4mm@gmail.com
weatherman5
If you could that would be very kind.
Enamul
Post by Enamul »
ok. No problem. I'll post to-night.
Enamul
enamul4mm@gmail.com
Enamul
Post by Enamul »
Here is the code promised. The LED need to be connected to RB3<PIN9 of PIC16f628> through 470 ohm resistor and crystal has to be external for this code which is 4MHz should be connected to 15 & 16 pin. But if you want I can tell you how to use internal clock if you need.
PWM_LED.hex
(924 Bytes) Downloaded 493 times
PWM_LED.fcf
(8 KiB) Downloaded 900 times
Enamul
enamul4mm@gmail.com
weatherman5
Hi Enamul
It was very kind of you to send me the code, I will try it out.
The bit I wanted to see most was the Flowcode you also sent, but the free trial I am running is limited to just a few PIC devices, my PIC not being one of them. So it will not let me see your flow chart. Would it be possible to send me a screen shot image of the Flowcode flow chart ? That will tell me everything I need to know before purchasing the software.
Thanks, Dave
Enamul
Post by Enamul »
Here is the screen shoots..
(23.84 KiB) Downloaded 8267 times
(54.39 KiB) Downloaded 4444 times
Enamul
enamul4mm@gmail.com
weatherman5
Hi Enamul
I very much appreciate your help with this, thank you Dave.
weatherman5
Hi Enamul
Thanks to your help I have purchased Flowcode 5 (Home) and have successfully designed my PIC and circuit so the led dims up, holds 100% then dims down, look great.
I was wondering if it was possible to add a light level detector to an input of the PIC, 16F628, so as to run the LED only when it was dark.
Dave
dazz
Has thanked: 474 times
Been thanked: 458 times
Post by dazz »
Hi Dave
have a look at this link http://www.matrixmultimedia.com/mmforums/search.php
you should find something in there
Dazz
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
There are several solutions for light level detection. One (simplest?) is to use a LDR connected to an analog input. Use the ADC component to read the input.
Wiring:
5V ------------ LDR ----+------- Resistor ------------ GND
                   PIC analog in
Resistor value depends on LDR characteristics. Try different values or use a potentiometer.
― C.S. Lewis
weatherman5
Hi kersing
I like your suggestion, very much what I had in mind.
So do you think I can connect this to PIC 16F628 ?
I guess if I can it would be to pin 17 or 18 AN0 / AN1.
Dave
dazz
Post by dazz »
Hi Dave
if you follow the link and type ldr in the box there are a few good posts with examples, if your feeling adventurous theres also some post on using an led to sample light got a few crude ones up and running
Dazz
BChappy
Has thanked: 13 times
Been thanked: 7 times
Post by BChappy »
Hi Guys,
Be aware that the 16F628a does not have an ADC, only comparator inputs!
I'm sure they'll be a snippet of code somewhere on here to do the light level detection with the comparator.
See post regarding 16F628a: http://www.matrixmultimedia.com/mmforum ... 46&t=10681
...and...
Welcome to the forum Dave!
Brian
Is your Project Not Working? - Help and General Advice Click here!
Flowcode v8 forum topic - Click here!
weatherman5
Hi Brian
Thanks for the welcome. I am enjoying programming up my first PIC.
I think light level detection with the comparator is just what I am after.
Dave
greentech
Flowcode V4 User
Has thanked: 10 times
Been thanked: 2 times
Post by greentech »
I can only see one pwm for 16f877a. I know there are two pwms for this chip. This has to be a bug or restriction in trial version?
greentech wrote: I can only see one pwm for 16f877a. I know there are two pwms for this chip. This has to be a bug or restriction in trial version?
No restriction on PWM with Trial version.
Do you mean you have set flowchart up correctly but can only see PWM on one of the hardware channels only
Or
You can only see one channel within your flowchart?
If the latter, then I have posted information on how to create more than 1PWM channel with Flowcode V5 here:
http://www.matrixmultimedia.com/mmforum ... 26&t=11694
Posting your Flowchart could help us to solve your issue more quickly.
greentech
Flowcode V4 User
Post by greentech »
here is a screenshot. i cant c 2nd pwm in component macro and over panel.
You need to add another PWM component, since you need to add an additional PWM component for each extra PWM channel your using.
E.g if your using 4 PWMs, you need to add 4 PWM components in total.
greentech
Flowcode V4 User
Post by greentech »
Aah! Silly me. i was used to fc4 :)
Sorry guyz, got it now.
No worries greentech these things can catch you out if use to a different way.
Just remember to set both PWM components with the same settings:
http://www.matrixmultimedia.com/mmforum ... 570#p43570
I have altered the above post to mention about a requirement to add additional PWM pomonents, so you have helped other people out, by bringing it to my attention.
Thank you for that :)
greentech
Flowcode V4 User
Post by greentech »
Keep up the good work brainiacs.
greentech
Flowcode V4 User
Post by greentech »
i am trying to understand how to init 3 level pwm to obtain 50Hz sine output. I have to use pic16f877a. i also need to put some lcd functions voltage readings from mains and battery etc.
greentech
Flowcode V4 User
Post by greentech »
How can i invert the pwm for pushpull loads.
