PWM using Flowcode V5
Posted: Tue Jan 15, 2013 6:27 pm
by weatherman5
I am running the free trial of Flowcode V5 and want to know if I can use it to bring an led from off to full brightness over say 0.5 second ?
I think this would be done using PWM which is built into the PIC I am using 16F628.
If I know it can be done I can purchase the full program.
Thanks, Dave
Re: PWM using Flowcode V5
Posted: Tue Jan 15, 2013 6:55 pm
by Enamul
It can be done in FCv5 very easily. If you want we can send you hex file so that you can test and decide to buy professional version.
Posted: Tue Jan 15, 2013 6:59 pm
by weatherman5
If you could that would be very kind.
Posted: Tue Jan 15, 2013 9:33 pm
by Enamul
ok. No problem. I'll post to-night.
Posted: Wed Jan 16, 2013 2:09 am
by Enamul
Here is the code promised. The LED need to be connected to RB3<PIN9 of PIC16f628> through 470 ohm resistor and crystal has to be external for this code which is 4MHz should be connected to 15 & 16 pin. But if you want I can tell you how to use internal clock if you need.
Posted: Wed Jan 16, 2013 10:34 am
by weatherman5
Hi Enamul
It was very kind of you to send me the code, I will try it out.
The bit I wanted to see most was the Flowcode you also sent, but the free trial I am running is limited to just a few PIC devices, my PIC not being one of them. So it will not let me see your flow chart. Would it be possible to send me a screen shot image of the Flowcode flow chart ? That will tell me everything I need to know before purchasing the software.
Thanks, Dave
Posted: Wed Jan 16, 2013 5:18 pm
by Enamul
Here is the screen shoots..
Posted: Wed Jan 16, 2013 5:25 pm
by weatherman5
Hi Enamul
I very much appreciate your help with this, thank you Dave.
Posted: Sun Jan 20, 2013 2:22 pm
by weatherman5
Hi Enamul
Thanks to your help I have purchased Flowcode 5 (Home) and have successfully designed my PIC and circuit so the led dims up, holds 100% then dims down, look great.
I was wondering if it was possible to add a light level detector to an input of the PIC, 16F628, so as to run the LED only when it was dark.
Dave
Posted: Sun Jan 20, 2013 7:39 pm
by dazz
Hi Dave
have a look at this link
http://www.matrixmultimedia.com/mmforums/search.php
you should find something in there
Dazz
Posted: Sun Jan 20, 2013 10:03 pm
by kersing
There are several solutions for light level detection. One (simplest?) is to use a LDR connected to an analog input. Use the ADC component to read the input.
Wiring:
5V ------------ LDR ----+------- Resistor ------------ GND
PIC analog in
Resistor value depends on LDR characteristics. Try different values or use a potentiometer.
Posted: Sun Jan 20, 2013 11:08 pm
by weatherman5
Hi kersing
I like your suggestion, very much what I had in mind.
So do you think I can connect this to PIC 16F628 ?
I guess if I can it would be to pin 17 or 18 AN0 / AN1.
Dave
Posted: Sun Jan 20, 2013 11:12 pm
by dazz
Hi Dave
if you follow the link and type ldr in the box there are a few good posts with examples, if your feeling adventurous theres also some post on using an led to sample light got a few crude ones up and running
Dazz
Posted: Mon Jan 21, 2013 9:51 am
by BChappy
Hi Guys,
Be aware that the 16F628a does not have an ADC, only comparator inputs!
I'm sure they'll be a snippet of code somewhere on here to do the light level detection with the comparator.
See post regarding 16F628a:
http://www.matrixmultimedia.com/mmforum ... 46&t=10681
...and...
Welcome to the forum Dave!
Brian
Posted: Thu Jan 24, 2013 8:14 pm
by weatherman5
Hi Brian
Thanks for the welcome. I am enjoying programming up my first PIC.
I think light level detection with the comparator is just what I am after.
Dave
Posted: Thu Mar 14, 2013 8:00 am
by greentech
I can only see one pwm for 16f877a. I know there are two pwms for this chip. This has to be a bug or restriction in trial version?
Posted: Thu Mar 14, 2013 8:30 am
No restriction on PWM with Trial version.
Do you mean you have set flowchart up correctly but can only see PWM on one of the hardware channels only
Or
You can only see one channel within your flowchart?
If the latter, then I have posted information on how to create more than 1PWM channel with Flowcode V5 here:
http://www.matrixmultimedia.com/mmforum ... 26&t=11694
Posting your Flowchart could help us to solve your issue more quickly.
Posted: Fri Mar 15, 2013 7:29 am
by greentech
here is a screenshot. i cant c 2nd pwm in component macro and over panel.
Posted: Fri Mar 15, 2013 7:55 am
You need to add another PWM component, since you need to add an additional PWM component for each extra PWM channel your using.
E.g if your using 4 PWMs, you need to add 4 PWM components in total.
Posted: Fri Mar 15, 2013 8:05 am
by greentech
Aah! Silly me. i was used to fc4
Sorry guyz, got it now.
Posted: Fri Mar 15, 2013 8:21 am
No worries greentech these things can catch you out if use to a different way.
Just remember to set both PWM components with the same settings:
http://www.matrixmultimedia.com/mmforum ... 570#p43570
I have altered the above post to mention about a requirement to add additional PWM pomonents, so you have helped other people out, by bringing it to my attention.
Thank you for that
Posted: Sun Mar 17, 2013 10:37 am
by greentech
Keep up the good work brainiacs.
Posted: Tue Mar 19, 2013 12:41 pm
by greentech
i am trying to understand how to init 3 level pwm to obtain 50Hz sine output. I have to use pic16f877a. i also need to put some lcd functions voltage readings from mains and battery etc.
Posted: Tue Mar 19, 2013 8:06 pm
by greentech
How can i invert the pwm for pushpull loads.
Posted: Wed Mar 20, 2013 10:54 am
