I want to display a number using 7 segment commun cathod
this is my program but it does not work with pic
thanks
help with 7 segment display
Re: help with 7 segment display
Hi nc56,
Since your using V5 Professional:
Support for Flowcode V5 customers using student/Home or Professional is done via the Flowcode V5 forum.
To be able to post in this forum your account has to be upgraded to a "Flowcode V5 User"
Please see the following link for more information:
http://www.matrixmultimedia.com/mmforum ... =46&t=9958
When your registered I'm sure we can post a solution for you
- STibor
- Has thanked: 116 times
- Been thanked: 113 times
Simple example Multiplex operation manual.
- led_mpx.fcf
- (11 KiB) Downloaded 306 times
bercioiu
- Has thanked: 90 times
- Been thanked: 34 times
Hi nc56 !
I fixed your file. When you use 7 segments display you have to connect all pins of the display. You have a warning when you connect the device witch said that if you don`t connect a pin of your device will don`t work properly but you ignored that warning. Your DP. for last two digits was not connected and RB7 witch was assigned for the first digit at DP in the last digit was assigned to common. Hope this work!
Later edit:
Hi STibor!
I fixed your file too. You miss the clear digit icon before to use the icon that the show the next digit.
Later edit:
Hi STibor!
- led_mpx_fixed.fcf
- (11.5 KiB) Downloaded 308 times
- 7se8_fixed.fcf
- (11 KiB) Downloaded 311 times
- STibor
You do not need to delete the display. The following 7 segment LED macro automatically rewrites the ports.Later edit:
Hi STibor!
The unused display common cathode float.
bercioiu
1. Test your file and my file, see what is good or not. You are wrong: if you don`t clear the display, the common of that display will light in the same time with the next digit .
2. I don`t understand what about the unused cathode that float... If you refer to the nc56`s file, he connect the first digit DP to the RB7 and at the digit two (or three i don`t remember now) he connect common to the same RB7
Later Edit:
If you write another number at the same digit, you are right, you don`t have to clear the old number. (it`s redundant)
Later Edit:
- STibor
If you do not have zero blanking, the code is good.
The video below shows the winding calculator.
The display control based on this principle.
http://www.youtube.com/watch?v=n4knCFvK ... e=youtu.be
