MIAC powered with 24V
Odox00
Flowcode v5 User
Post by Odox00 »
I'm interesting in using a MIAC in a project at my work. Since I'm used to program in Flowcode.
Thing is that all other equipment in the project will run on the industrial standard 24V. I noticed that MIAC power supply voltage is 12-16V. Will the MIAC unit blow if I feed it with 24V? If so, I have to use the Crouzet millenium 3 instead.
Jeppe
Don't say oups!? Say Interesting!
Has thanked: 481 times
Been thanked: 699 times
Re: MIAC powered with 24V
Using 24V is not advised. The MIAC will probably not blow, but you might have long term reliability issues, depending on how it is used, ambient temperature, etc.
It would be best to provide a separate supply, either stepped down from 24V or AC adapter, for the MIAC supply, which nominally consumes around 100mA. The transistor/motor driver supply can be as high as 24V.
