Programmer Selector !
acestu
Has thanked: 783 times
Been thanked: 223 times
Post by acestu »
I think a programmer selector in the menu would be really handy so that if you use 2 or 3 different programmers you can store the
parameters in settings and then just select the programmer that you want to use in a drop down menu...
thanks
Acestu
Re: Programmer Selector !
I think this is currently possible. Setup the compiler options as you need for the programmer or compiler then type a new name in the text box next to Option list: then click the disk icon to save the profile. The entire compiler options profile can then be selected from the drop down menu.
Here are some profiles I have saved,
BoostC + EB006
BoostC + PICkit2
BoostC + PICkit3
HiTech + EB006
BoostC Large Arrays + EB006
etc....
You can even export and import profiles.
acestu
Post by acestu »
Thanks Ben,
I will have a look at that now, that's brilliant news...
cheers
Acestu
