I have not received the email to download the software Flowc
Forum for problems or queries regarding the Flowcode application and compiler usage.
alexandrep
Has thanked: 1 time
Post by alexandrep »
Please, I made the purchase of Flowcode pic home on Saturday, and was not sent
e-mail to download the software.
Verifquei if the email was in spam but is not.
What should I do, I can cancel the purchase?
The software was flowcode5 - pic - Home
My e-mail is alexandre@linear-hcs.com.br
I have to ask to see the cd rom?
one more thing, I tried, register on the forum email alexandre@linear-hcs.com.br,
but the system did not send the e-mail confirmation.
I would use this is possible?
Alexandre
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: I have not received the email to download the software F
Post by Enamul »
PM to DavidA, he will sort the issue. Don't cancel the purchase. It's simple issue for MM guys in office time. I am sure it will be sorted tomorrow.
Enamul
University of Nottingham
enamul4mm@gmail.com
alexandrep
Has thanked: 1 time
I would like to cancel the purchase,
I did not like, I can not write the pickit 3, has not had a good experience in buying, the serial was not sent to my email. alexandre@linear-hcs.com.br
nor activation of the forum, I had to change the e-mail.
Please send me an e-mail I send cancellation to the credit card.
alexandrep
Has thanked: 1 time
Ok, I got the link, but will install on pc from home overnight.
I'm with versçao demo on a pc with windows 7 32bit and I can not do the work pickit3, I've seen all the details but fórium plumb so, says the writer pickit 3 is not connected to USB.
It is of great value I can use Flowcode 5 on recording coupled with pickit 3.
You guys have a way of making passoa by step, to see where the problem might be?
tks
Enamul
Post by Enamul »
For PICKIT3 you should go to the following page..
http://www.matrixmultimedia.com/support ... f=68&t=786
Enamul
enamul4mm@gmail.com
alexandrep
Has thanked: 1 time
Hello, good morning.
I installed the software and found it very good ...
but still can not work with those settings pickit 3 following you guys sent me the link.
You guys have a tape recorder running the Matrix product?
Alexandre
Enamul
Post by Enamul »
Is your OS is 64-bit or 32-bit?
Enamul
enamul4mm@gmail.com
alexandrep
Has thanked: 1 time
It is 64bit, but I tried on 32 bit also, following every tutorial,
following file to verify that selected right and error that is occurring.
https://docs.google.com/file/d/0B1ZqTf4 ... sp=sharing
alexandrep
Has thanked: 1 time
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
For use with pickit you should not use filenames with spaces. Please save your project as count.fcf and try again.
― C.S. Lewis
alexandrep
Has thanked: 1 time
He continued appearing the same mistake.
kersing
Post by kersing »
Could you try changing the options to
-P%p -F"%f.hex" -E -M
― C.S. Lewis
alexandrep
Has thanked: 1 time
Hello, gave a different message device not found.
It is as if he had the pickit3 installed on USB, but it's because I can write by MPLAB.
Thanks so far ... you can not make a video and put on youtube?
error
alexandrep
Has thanked: 1 time
correct pickit3 not installed in USB .
alexandrep
Has thanked: 1 time
Please. someone could help me solve this problem I am having the message device not found?
https://docs.google.com/file/d/0B1ZqTf4 ... sp = partilha
Try closing MPLAB as this takes hold of the PICkit and doesn't let go for other applications to use at the same time.
alexandrep
Has thanked: 1 time
Thanks for the reply.
I did not leave open the mplab and overifcando dispopistivos in windows it is properly installed.
The message Device is not found.
You've got one more observation?
alexandrep
Has thanked: 1 time
Hello, everyone, thanks for the feedback could find the problem now is working very good software.
a hug
Alexandre
:D
Enamul
Post by Enamul »
Glad to know finally your issue is sorted.
Enamul
enamul4mm@gmail.com
