GLCD two different control ports
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
Post by Jordy101091 »
Hi all,
I have made a prototype PCB where I have connected a GLCD (KS0108) to this microcontroller PIC18F452.
The data lines of the Glcd are connected to PORT.D 0 to 7.
The control lines:
CS2 & D/I are connected to PORT.C 3 & 0
CS1 & Enable & R/W are connected to PORT.E 0 to 2
I have found on the forum that you could make another define in the C code, I have done that, and named it: MX_CONTROL_PORT2, MX_CONTROL_TRIS2
In the "GetDefines" I have altered all code where CS1, Enable, R/W from:
void MX_Write_Command(char cmd, char chip)
	if(chip == MX_CHIP1)						//Select Chip 1
		clear_bit(MX_CONTROL_PORT, MX_CS2);
		set_bit(MX_CONTROL_PORT, MX_CS1);
	else if(chip == MX_CHIP2)					//Select Chip 2
		clear_bit(MX_CONTROL_PORT, MX_CS1);
		set_bit(MX_CONTROL_PORT, MX_CS2);
To
		set_bit(MX_CONTROL_PORT2, MX_CS1);
		clear_bit(MX_CONTROL_PORT2, MX_CS1);
The same I have done in this file "LCD_Init" To:
clear_bit(MX_CONTROL_TRIS2, MX_ENABLE);				//Convert control pins to output
	clear_bit(MX_CONTROL_TRIS, MX_DAT_INST);
	clear_bit(MX_CONTROL_TRIS2, MX_CS1);
	clear_bit(MX_CONTROL_TRIS, MX_CS2);
	clear_bit(MX_CONTROL_TRIS2, MX_READ_WRITE);
	set_bit(MX_CONTROL_PORT2, MX_ENABLE);
	clear_bit(MX_CONTROL_PORT2, MX_READ_WRITE);			//Write Command
	clear_bit(MX_CONTROL_PORT, MX_DAT_INST);			//Instruction code
	set_bit(MX_CONTROL_PORT2, MX_CS1);					//Select Chip 1
	MX_Write_Command(MX_LCD_ON, MX_CHIP1);				//Switch on LCD controller chips
	MX_Write_Command(MX_LCD_ON, MX_CHIP2);
	MX_Write_Command(MX_LCD_DISP_START, MX_CHIP1);		//Configure the display start address
	MX_Write_Command(MX_LCD_DISP_START, MX_CHIP2);
	LCD_Clear();
	MX_GotoXY(0,0);
The only problem I have now is that When I print Test on the screen as string the its show two times.
Just if CS1 and CS2 are activated together. Thit I miss something can somebody look into this please,
Thanks you.
Regards Jordy
I have added the Getdefines file and LCD_Init File I dont know if i could help?
GetDefines(GLCDKS0108).fcc
(21.94 KiB) Downloaded 200 times
LCD_Init(GLCDKS0108).fcc
(21.94 KiB) Downloaded 205 times
