- Is Flowcode V5 compatible with any of the XC compilers?
- I have both versions, the one for PIC and the one for dsPIC.
- I know that the syntax is very similar to that of the Hi-TECH compilers, so I presume I can just replace the compiler options suggested for HI-TECH in the help with XC parameters; will this work?
- I would like to know if there are compatibility problems before engaging in a programing adventure that may not end up well.
Thank you all beforehand.
Compatibility with Microchip's XC compilers
Re: Compatibility with Microchip's XC compilers
We have not tried Flowcode with the XC range of compilers. It will probably work quite well but there are bound to be issues.
If you give it a go then let us know how you get on.
There is a guide to setting up the HiTech compiler available from here.
http://www.matrixmultimedia.com/mmforum ... =26&t=6812
