Remote recorder
Tony Brown
Has thanked: 36 times
Been thanked: 5 times
Remote recorder
Post by Tony Brown »
Anyone know how I would go about making a flowcode prog that when you point a remote control at it, it stores the remote signal in the eeprom that then can be recalled by the push of a button. Basically I am trying to make a remote control copier for a single function remote control.
Tony
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: Remote recorder
Post by JohnCrow »
Matrix had an article published in the June 2011 issue of Elektor Magazine on this subject.
The article itself and the flowcode can be download from their website.
This is currently a free download, though Elektor do normally charge a small fee for articles.
Though the article uses the dsPIC board I'm sure if you import the flowchart into the standard pic version you should be able to get some ideas.
http://www.elektor.com/110315
Hope this helps
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: Remote recorder
Post by Enamul »
You can have a play with the posting of Martin and make your own one..
http://www.matrixmultimedia.com/mmforum ... RC5#p45205
Enamul
University of Nottingham
enamul4mm@gmail.com
Tony Brown
Re: Remote recorder
Thanks for that both sources of information recommended looks really useful, will give it a go.
ThanksThanks
Re: Remote recorder
John also created a very useful test program which displays information received from remote control on a LCD.
http://www.matrixmultimedia.com/mmforum ... 67&#p39867
You can use this information to store in EEPROM.
