How can this be accomplished ?
To use Flowcode component macro with RFID Chip without using E-blocks RFID component
It's the first time to use RFID component macro so can you help me ?
And any one knows easy custom RFID readers to be built ?
I need to build a user Authentication door lock using RFID Identification
Thank you for help in advance
How could i use Flowcode with RFID Chip other than E-blocks?
- Flowcode v5 User
- Has thanked: 5 times
Re: How could i use Flowcode with RFID Chip other than E-blo
The Flowcode component code is designed to work with the modules from RF solutions which are the modules we use on the RFID E-block.
http://www.rfsolutions.co.uk/acatalog/R ... odule.html
Most RFID modules communicate using a serial bus which can be driven using the RS232 Flowcode component so if you wanted to interface to a different module this is probably possible.
