I need help. I have made a project in Flowcode V4 and V5 that was perfectly running on my EB-006 board with Eblocks. Now I made my stand alone board but even the most simple things will not work.
What I did for example was the attached programm.
(Note the display is not connected the default way as on Eblocks some mins are swaped for easy routing of the PCB)
I hooked up a display to a PIC 16F877A the folowing way.
Display - Pic (pins)
4 - 7
6 - 6
11 - 5
12 - 4
13 - 3
14 - 2
Display pin 1 - VSS pin 2 - VCC pin 3 - contrast adjusted wit a potentiometer.
Xtal 19.6608 Mhz connected to pins 13 and 14 with 2 15pf caps to ground
VCC to pin 11 and 32
VSS to pin 12 and 31
Pin 1 with 10k to VCC
When I power this up nothing appears on the display, who is able to help me out on this?
None of my project will run when not on the EB-006 Board
- Flowcode1.fcf
- Hello World Flowcode V5
- (5 KiB) Downloaded 312 times
Re: None of my project will run when not on the EB-006 Board
Hi Albert.
I have not got time to check your hardware pin for pin, but are you sing the same flowchart that worked with your Eblocks?
Reason for asking is because you have not got the correct configuration settings (Chip, Configure... menu).
Oscillator should be set to HS
Watchdog timer should be off.
Low voltage programming should be disabled.
Have you read this?:
http://www.matrixmultimedia.com/mmforum ... =26&t=6936
Its best to get flowchart correct before working on your hardware side.
Also It's a good idea with every new flowchart to create a 1Hz flasher.
Then connect an LED and current limiting resistor to an output pin of your target device to make sure all configuration settings are correct.
This is especially useful for devices that have more complex configuration settings.
Martin.
Martin.
Thank you Martin for your reply. I have checked the topic and have seen a lot of options I did not try so this evening I will give it a new try.
One additional question. About 1.5 year ago I was always able to program devices on the EB-006 with Eblocks connected. I did not work with Flowcode for some time and now found after the update to V5 that I can not program any device without first disconnecting alle Eblocks. This is experianced as verry annoying. Is this a settings or hardware failure?
I find it depends on what microcontroller is being used.
With some target devices need programming twice, others require hardware to be removed, and others program just perfect every time with other Eblocks connected.
So you programmer is probably just fine.
I know with V6 it's heading away with PPP, which may resolve issues assuming failure is associated with timings of PPP?
PPP timing may or may not be the cause, I'm only guessing at that?
Martins tip about the 1hz flashing led solved the problem. I forgot to connect pin 5 of the display to ground, so my project was running just fine only the display could not display anything. So from now on whenever I have a spare IO port I will always have the led within my project.
Thanks Martin for your great help
Your welcome Albert38,
Glad its all sorted now.
Thanks for the update.
