MIAC Real Time Clock using the Advanced Expansion Module
Dave @Harper Adams
Post by Dave @Harper Adams »
Has anyone used the RTC function on the MIAC advanced expansion module? As far as I can make out from the help files you have to first initialise the module then update the local time variables from the RTC registers. Each variable (Hr/Min/S) can the be read into separate variables. I'm then trying to dispaly the variables on the MIAC's display.
Currenty the program downloads, usually just displays 0:0:0 (somtimes 0:0:4).
Any ideas?
Dave
Simple RTC.fcf
Simple real time clock
(9.5 KiB) Downloaded 375 times
Re: MIAC Real Time Clock using the Advanced Expansion Module
Hi Dave,
Attached is Flowchart that should display time and date just fine.
I believe that attached flowchart was also placed within MIAC System Flowcode Examples
found here:
http://www.matrixmultimedia.com/miac.php
There is a small bug within Flowcode that may require you to select Miac Advance Initialize again before able to run or compile.
after saving should be ok to run.
Miac Advance expansion RTC Demo .fcf
(49.97 KiB) Downloaded 366 times
Dave @Harper Adams
Thanks Martin
I'll give it a try.
Dave
Dave @Harper Adams
Hi Martin
I tried the file you suggested but it didnt work.
The MIAC appeared to be senting info to the advanced module (as it was putting the LED on), but not receiving the RTC data back.
I connected a CAN analyser to the CANbus and some messages were being sent but others were not.
I then checked what level of sofware I had and there was a leter version. Uploaded the latest V5 version and the program worked (after re-adding the module initialization).
Then tried my original program (after re-adding teh module initialization) and that works too.
With hindsight I should have checked the level of software. But I have learnt a bit about the structure of the CAN massages and that there are several other good examples on the web which will be useful for the next part of the project.
Thanks Dave
Long as you're up and running now, thats the main thing.
Thanks for updating us.
martin
