8bit lcd display
john hauton
Been thanked: 2 times
8bit lcd display
Post by john hauton »
Hi, its probably been asked before, but search couldn't find what I'm looking for.
I'm looking for a way of using an 8bit lcd interface. The reason being it's supposed to be faster.!?
Is there a way of modifying the character lcd routine that will allow an 8bit configuration?
Thankyou, regards john
brandonb
Has thanked: 175 times
Been thanked: 173 times
Re: 8bit lcd display
Post by brandonb »
it would be 200u/s per char since it would be sending a full byte instead of nibbles, i don't understand how the defines are used from within flowcode so sorry can't help with the mod's,
I have a 8-bit version of the component's C file. It is a bit hacky as I think the port pins are hard coded in the C file itself. Can you confirm which version and varient of Flowcode your using and I will see if my file is compatible.
john hauton
Hi Benj,
Sorry about the delay, health issues...
I'm using flowcode v4.5 pic
(version 4 with updates)
is that what you need?
thanks & regards John
Hi John,
Here is an 8-bit v4 component C file for AVR. You could maybe have a look at putting the changes across into the PIC version yourself. If your having problems then let me know and I will see if I can make the changes for you.
LCDDisplay_Code.c
(6.14 KiB) Downloaded 398 times
