- can i store signed char's to arrays and luts?
- can i convert a unsigned char or unint to signed with it not remaining positive if i inteded negative for that number position, for instance if i store a unsigned 2 in an array and transfer it over to a signed variable how can i make it be the negative equivelant?
- the thing that i want to do is make a correction table by storing a signed char to a lut, pull it out add it to a unsigned char so i can add and subtract from the unsigned number, i guess if i knew the laws of it it would be obvious but don't know how it works yet,
taking a guess i could store as signed char if possible to lut, pull it out and transfer it to signed int with c code, transfer other unsigned char into signed int, then so all the math with both ending variables being signed, then convert answer back to unsigned to use with the delays as the answer is always gonna be positive?
does that make any sense
