HI All,
As I'm struggling in rs485 communication. i designed flow chart that is working perfectly with rs232. I f connecting multiple boards I'm failed to send the output from the pc to Particular board. Here I'm in need of master addressing, Pls request all to help me out in this regards.
Here I'm adding the flow code file.
RS485 COmmunication
- Has thanked: 553 times
- Been thanked: 1081 times
Re: RS485 COmmunication
I moved your message as the tips & tricks forum is meant to share knowledge, not to ask for help. If you use one of the links below the message can be moved to a more appropriate forum (Flowcode 5).
― C.S. Lewis
― C.S. Lewis
