I need to divide a time for an engine revolution by 360 to get time per degree.
This will obviously be a .000 something or other so can you point me in the right direction on being able to read this in flowcodev5?
I've tried it as a standard calculation but it returns nothing. Well, perhaps some thing that will not register as it is too small..??
division
Re: division
HI Bluejets
Firstly can you follow the link in my sig and sign up to the forum relevant to the version of flowcode you are using, also can you post your flowchart as it makes it much easier for people to give help and advice
search the forum for rev counter, tacho or rpm as there are a few samples here, if you need to use a number that has a decimal point you need to set up a float variable
Dazz
Dazz
