Lcd has a problem with auto resizing of the display when changing from 2 x 16 have to resize manually to correct.
and is there a way to speed up assigning what port they connect to rather than one at a time it take to long.
Wayne
LCD problems
wayne millard
- Has thanked: 7 times
- Been thanked: 12 times
Re: LCD Help
Hi Wayne,
Lcd_eb005 is an eblock, therefore that will always be the same as shipped with eb005 eblock
If you would like a different size, then you will need to drag a different lcd component on to your panel:
in all fairness every pin use to default to 0, you can imagine what pain that was, so I suggest at least it should be the way it was in FC5.
I also suggested if you change Data 0 all the others change.
But I have an idea I will place in Feature requests.
Trust me, I have nagged about this one on more than one occasion.wayne millard wrote:is there a way to speed up assigning what port they connect to rather than one at a time it take to long.
