Densitron LMRD4265
Tony Brown
Has thanked: 36 times
Been thanked: 5 times
Densitron LMRD4265
Post by Tony Brown »
I have managed to get my hands on a Densitron 128 x 128 GRAPHICS LCD, does anyone know if there is a custom code for this display?
It uses controller T6963C.
Thanks in advance
Tony
Re: Densitron LMRD4265
Hi Tony,
I can have a go at adding this type of display into the v6 Beta if this would be any good for you.
Tony Brown
That would be really good :-)
Tony Brown
Hi Benj
I have a copy of the lcd driver is it possible to include it in my flowcode program so that I can use the display?
Can I just put the .C files from the driver into a C box?
Tony
Hi Tony,
If you look at the v5 examples then there is a file that shows how to either embed C into the C icon or how to reference external C files. The C code would have to be syntactically correct for your compiler and so may require porting.
http://www.matrixmultimedia.com/lc_index.php?p=18
As for getting into the v6 beta, I have found source code which look promising and have started to convert the code into a component, hopefully be in for the next release.
Tony Brown
Hi Benj
Any idea when the next release will be?
I have looked at the glcd driver and there is other files that are not C files, will the lcd still work with only the C files do you know?
Tony
Tony Brown
Hi Benj
Did you have any luck with including the glcd in flowcode, I purchased V6 and am eagerly waiting for the file.
Tony
