When loading an FC5 Flowchart, after on occasions asking to save twice, Flowcode then minimises so you have to select it's icon (e.g on the task bar) to maximise in order for it to be in the foreground.
I't does not do this when loading .fcfx extension.
FC6 minimises when loading V5 flowchart.
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: FC6 minimises when loading V5 flowchart.
Bizzare. I'll have a look into the loading twice issue as well, and see why this is happening. Did the minimise only happen once?
Jonny
Jonny
It only minimises once, and just when first save as window appears.
So you only see the save as window as Flowcode is then minimised.
