Hi guys,
I am not sure if this is supposed to be, maybe because FC6 is a Beta, but you can't open 2 instances of FC6 ie 2 different charts, also when you double click on a FC6 file the program opens then closes straight away..
Acestu
Only 1 instance of FC6 at a time ? - Resolved
- acestu
- Has thanked: 783 times
- Been thanked: 223 times
Re: Only 1 instance of FC6 at a time ?
Hi Stu,
Are you running the latest patchset 2? If not then please can you update and check to see if the problem still exists.
I run multiple instances on my dev machine so I can copy code from one program to another, wonder if it could be a license issue? If you click the shortcut from the start menu does this allow you to open more then one instance?
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Just tried multiple instances on both my systems, works fine. (Both running latest patch) I didnt try it with earlier versions so dont know if there was a problem
Also FYI I can only run FC on one (networked) system at a time so that part of the licence is working ok.
- acestu
Hi Guys,
Sorry I didn't see patch set 2 there, as it is quite new, anyway I have installed and I can now open multiple charts, however with nothing open if I double click on a FC6 chart icon the program tries to open but closes straight away...
Acestu
System Used:
Windows XP Pro 32 bit
Acestu
System Used:
