Got a component using an 8 bit data port. When selecting PortD_L the wrong port is chosen (PortD_H), setting it from D_H to D_L results in the correct value.
(Jonny, VFD_base as I PMed to you shows this issue)
Port selection for Port D_L displays D_H
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
― C.S. Lewis
― C.S. Lewis
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: Port selection for Port D_L displays D_H
Hi Jac. Thanks for the spot.
The pin selection stuff had a bit of v5 legacy in it and was a litte bit of a mess. I have redone this now, and hopefully should not show these issues.
Jonny
Jonny
