Just trying to find out if all of us are affected or just a few.
It looks like the 5day warning caused failure to compile to Hex with PIC selected on my PC
Would you mind posting if you can/can't compile to hex.
How many Flowcode V6 uses Can't compile 8bit PIC? - Resolved
- Jordy101091
- Has thanked: 25 times
- Been thanked: 188 times
Re: How many Flowcode V6 uses Can't compile 8bit PIC?
I cannot compile to hex also, I mentioned this before and I hope there will be a fix soon for this.
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Hey guys, this is a strange thing, we will try fix asap.
A simple pic 24EP.. projekt I can compile ; also with the 5days warning.
I change to a pic18f45k22 and have a error ??????(the same in v5.2 work ok)
what is after 5 days????
Regards Wolfgang
Regards Wolfgang
- (76.38 KiB) Downloaded 1373 times
- (91.51 KiB) Downloaded 1373 times
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Hi. Looks like all of you!
The same popup that shows the timeout warning is popping up as a hidden window when the compiler launches. I have removed the warning in the upcoming patch and the compiler seems to behave now.
Jonny
Jonny
