I am putting togethor a chart to read the data from knob0 on the 4D display then output the data to an lcd and meter0 on the 4D display, when I run a simulation It takes 7 or 8 clicks of the stop button to end, as if you are waiting for something to end..?..
thanks
Acestu
P.S. The meter on the 4D display is not responding properly
7 or 8 tries to stop simulation
- acestu
- Has thanked: 783 times
- Been thanked: 223 times
Re: 7 or 8 tries to stop simulation
Hi Stu,
In Simulation try adding a delay. Continually polling the COM port in a tight loop was causing me some problems too so I'm hoping this is the cause. Adding say 100ms to the loop helped a great deal. You should remove this delay for an embedded target. In the mean time I will investigate the DLL to see if I can work around the issue there so others won't have to.
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Hello. Is the simulation speed 'as fast as possible' or 'normal'? With 'as fast as possible' simulation will be pretty greedy and hog the CPU, and this will have varying results on different CPUs. Normal should allow things to update smoothly, so long as there is no DLL call that is holding things up.
Jonny
Jonny
- acestu
Hi Jonny,
this happens on the normal setting as per pic enclosed...
Acestu
Acestu
Hi Stu,
Do things improve if you add say a 100ms delay into the loop?
- acestu
Hi Benj,
I have just put the delay in the loop and the simulation now stops first try ...
thanks
Acestu
thanks
Acestu
Cheers Stu,
The issue is the DLL and not Flowcode, I will try and fix it before the release.
