When trying to add element to a lookup table from a byte array using AddInt the elements are added as 0, not the actual value.
See attached flowchart, elements 2-4 should not be zero. (Output is in Component debug window)
Dynamically adding LUT from byte array fails
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
- lut_test.fcfx
- (7.75 KiB) Downloaded 436 times
― C.S. Lewis
― C.S. Lewis
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: Dynamically adding LUT from byte array fails
Hi. A typo in a previous bug fix introduced this - seems like fixing the 'pass arrays by-ref bug' is like trying to build a house out of bars of soap.
Either way, it is now fixed, and hopefully will be sorted.
Jonny
Jonny
