Keep aspect ratio option would be handy.
So if one value is changed then the other two values are automatically changed (by manually changing or dragging with the mouse) keeping the correct aspect ratio.
World Aspect Ratio
Forum rules
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: World Aspect Ratio
Hi. If you hold shift down when dragging the mouse this will lock the aspect ratio.
Doing this in the properties window has been asked for before, its just something I haven't sorted yet. Shouldn't be long.
Cheers,
Jonny
Cheers,
Jonny
Hi Jonny, thanks.
I found the issue was when object was too small to drag larger.
entering a value then and keeping the aspect ratio would be ideal.
