Programming tool selection
Please add any feature requests for Flowcode version 6 here
Forum rules
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
Post by Jordy101091 »
HI all,
It would be nice if you could choose if you want to programming using pickit2 or 3 and EB006.
For example if you want to program A chip and you click the "Compile to chip" there should be a popup box that lets you decide which programming tool to use.
Im now programming with my pickit 3 but when I want to program with EB006 I need to change all the configuration.
This is very time consuming,
I hope this can be implemented.
Jordy
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Programming tool selection
Post by kersing »
Hi Jordy,
Have you noticed the floppy symbol at the top right of the compiler options dialog? It allows saving the settings which will be show in the list on the left. So if you change the settings and save them using a new name you should be able to switch between settings. Using the export/import buttons you can also save them to exchange with other users. (The help button '?' on that screen provides useful information)
Jac
― C.S. Lewis
Jordy101091
Re: Programming tool selection - [Solved]
I didn't notice that thanks for pointing out.
This will help.
Regards Jordy
